1
This discussion topic has been answered Discussion topic: Sound dropping out on certain recordings
This message was authored by: allenwynne10
Whenever I record a programme on my Sky Q box, especially the Request Channel, the sound keeps dropping out for seconds, then comes back on. This doesn't happen when watching Request live or on catch-up. I have rebooted many times to no avail. All other recordings are fine ?????
Re: Sound dropping out on certain recordings
Hi @allenwynne10
Hi @allenwynne10
