Discussion topic: Mini boxes won’t connect
Message posted on 20 May 2025 08:38 PM
After a long wait and some traumas with Sky and OutOfReach along the way, I've finally been upgraded from and old Sky Superfast copper connection to Sky Fibre 150. This includes the the latest Sky Max Hub and Max Pod.
All installed and up and running today. Speed test (via OpenSignal) shows 149mbs Down and 29mbs Up which is what I expected.
However, despite promises from Sky that the new setup would eliminate occasional dropout issues with my Q mini boxes, it appears to have made things much worse! Despite following all of the advice in this site about rebooting all of the boxes and resetting network connections....neither box will stay connected on the network. I thought I'd solved it but when I switched the boxes back on, it came up with an error message and no connection. I've gone through the whole process several times and have given up now.
WiFi is working elsewhere in the house and the connected TVs are connecting fine. It's just the mini boxes that won't work.
Main Q box is less than 1m from router and connected via Ethernet. Both 2.4 and 5 are off on main box (as advised by Sky engineer). Mini boxes are in upstairs bedrooms with no access to cat5 so rely on wireless. 2.4 and 5 are on.
Any help and advice gratefully appreciated.
Message posted on 20 May 2025 09:18 PM
Re: Mini boxes won’t connect
Hi @DSN6
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router (not Sky Max) if on Sky Broadband or previously connected mini).
Message posted on 24 Nov 2025 03:56 PM
Need to speak to someone
