This discussion topic has been answered Discussion topic: Mini boxes with recent connectivity problems
Message posted on 17 Jul 2024 01:28 PM
They switch every minute or so between showing a channel and a blue screen with this message:
- You can't currently watch TV as there's an issue with the connection between this Mini Box and your Sky Q box
Main Sky Q is a 2TB Box9028 and is working fine as were the Minis till last week. Have updated, restarted and reactivated everything but it has made no difference.
Software version on all is Q270.000.08.00L (5u193c0)
Any help much appreciated.
Message posted on 31 Jul 2024 10:58 AM
Yes, resolved. Called an engineer who reckoned the main box had a fault. He replaced it and now all seems well.
Message posted on 18 Jul 2024 09:13 AM
Re: Mini boxes with recent connectivity problems
Hi @Andrew485
Your post has been escalated to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Just look out for the chat bubble to start the conversation.
Here's more information on how Community Messaging works - https://community.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
Tom
Message posted on 18 Jul 2024 09:18 AM
Hi @Andrew485 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, then do the same with any Mini boxes?
Message posted on 18 Jul 2024 10:04 AM
Have done all the unplugging for 30 seconds but it hasn't helped
Message posted on 18 Jul 2024 10:53 AM
Hi @Andrew485
Try a Network Reset on the minis. Start with the one nearest to the main Q box
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
Message posted on 19 Jul 2024 10:14 PM
Hi, did you get this sorted out as I have exactly the same problem?
Message posted on 07 Nov 2024 05:13 PM
I had same problem and powered down the mine box. Then went to main sky Q box and in the status settings section I reactivated the mini box even though it was showing a tick against it. Mini box then started working. Maybe even worth just trying reactivating mini box on main sky q box first
Message posted on 19 Nov 2024 10:48 PM
My mini box keeps loosing connection with the main box aver time I turn on the mini box. This is really peeing me off. Not impressed
