7
Discussion topic: Mini boxes with recent connectivity problems
This message was authored by Andrew485 This message was authored by: Andrew485
They switch every minute or so between showing a channel and a blue screen with this message:
  • You can't currently watch TV as there's an issue with the connection between this Mini Box and your Sky Q box
Main Sky Q is a 2TB Box9028 and is working fine as were the Minis till last week. Have updated, restarted and reactivated everything but it has made no difference.
Software version on all is Q270.000.08.00L (5u193c0)
Any help much appreciated.
Andrew485
This message was authored by Andrew485 This message was authored by: Andrew485 Answer
Re: Mini boxes with recent connectivity problems
Yes, resolved. Called an engineer who reckoned the main box had a fault. He replaced it and now all seems well.
This message was authored by Tom-W19 This message was authored by: Tom-W19
Posted by a Sky employee
Hi @Andrew485
Your post has been escalated to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Just look out for the chat bubble to start the conversation.
Here's more information on how Community Messaging works - https://community.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
Tom
This message was authored by Quoman7 This message was authored by: Quoman7
Hi @Andrew485 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, then do the same with any Mini boxes?
Andrew485
Have done all the unplugging for 30 seconds but it hasn't helped
Hi @Andrew485
Try a Network Reset on the minis. Start with the one nearest to the main Q box
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
This message was authored by andyharris2 This message was authored by: andyharris2
Hi, did you get this sorted out as I have exactly the same problem?
Andrew485
This message was authored by RainmanSteve This message was authored by: RainmanSteve
I had same problem and powered down the mine box. Then went to main sky Q box and in the status settings section I reactivated the mini box even though it was showing a tick against it.  Mini box then started working. Maybe even worth just trying reactivating mini box on main sky q box first
