5
This discussion topic has been answered Discussion topic: Sky Q mini as main TV
This message was authored by: Mrstevemoore
hi folks,
first time contributor.
My TV is not close enough to where the sky cables come into my house and getting sick of the cables.
if I plug in my main Sky Q box near the router and where the Sky comes without a TV and plug a mini Q to main TV... will this solve my issues with cables?
I have looked at wireless HDMI but seems that won't work.
This message was authored by: PandJ2020 Answer
Re: Sky Q mini as main TV
@Mrstevemoore wrote:
Sorry I should be clear, my plan is to plug in my main Sky Q box without A TV but powered on.
Yes you can do that.  As long as the main box has satellite feeds then the mini can be used.
Yes, you can do that.  Just to note that the mini's do not support UHD if that's something you have.
Avatar for Mrstevemoore
I'm not worried about UHD.
thank you for the reply, is it likely to cause any issues or me having to connect a TV to the main Q box?
Thank you.
