Discussion topic: Mini boxes not working
Message posted on 16 Feb 2025 10:59 AM
Recently upgraded to sky fibre broadband but mini boxes not connected to wifi
Message posted on 16 Feb 2025 11:09 AM - last edited: 16 Feb 2025 11:11 AM
Re: Mini boxes not working
Hi @Drcw
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
However if you have the new Sky Max router connect to the main Q box not the max router.
