Discussion topic: Viewing card not active
Message posted on 13 Feb 2025 05:09 PM
flagged this query 4 hours ago waiting on what's app reply. Tried all recommendations take out card, re boot, unplug
Message posted on 13 Feb 2025 05:16 PM
Re: Viewing card not active
Hi @DeeFee1
First check that your viewing card is correctly inserted. Viewing card is in the right hand end of the box.
If it is in correctly there is not enough of it sticking out to grip and remove it.
Push it fully in and it will pop out slightly enough so you can remove it.
Take it out and give the chip a gentle wipe with a damp lint free cloth or E-cloth.
Ensure that it completely dry before you reinsert it chip side up and chip end in first. Push it gently fully in and you should feel a slight click when it is engaged. If it has popped out enough to remove it is not located correctly.
If you are satisfied that it is in correctly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
Message posted on 13 Feb 2025 05:29 PM
Still showing viewing card not active
Message posted on 16 Feb 2025 10:40 AM
Problrm resolved
Message posted on 16 Feb 2025 10:42 AM
@DeeFee1 wrote:
Problrm resolved
Could you post how (if it differed from the advice from @oldfella ) so that it may help other customers viewing this thread in the future?
