Discussion topic: Mini box
This message was authored by: V3rnf
Mini box
I have three mini boxes can I have a fourth and how much is it?
Re: Mini box
Hi @V3rnf
If you are new to the forum then welcome to the Community which is predominantly made up of Sky customers helping other Sky customers. You aren’t actually talking to Sky by posting on here.
Sky will loan you a maximum of 4 mini boxes. You can watch Sky content on two minis and the main box at the same time. You may be able to use a third mini box if the first one in use is being used for a streaming app ie: Disney+. That limit does not change if the main Sky Q box is not being viewed. Remember that UHD content can’t be viewed on a mini box.
The original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one monthly Multiscreen subscription.
▪️I AM NOT A SKY EMPLOYEE ▪️
