Discussion topic: Problem with Q box
This message was authored by: Adsley
Problem with Q box
The Q box sometimes fails to record programmes
On replay it can freeze
whatever is recorded has an associated software  problem message
We Had an upgrade f the network yesterday and I asked the engineer who said it was probably a disk problem.
Re: Problem with Q box
Hi @Adsley
