Discussion topic: Mini box
Message posted on 25 Nov 2024 06:21 PM
Mini box
You can't watch YV at the moment as there is a connectivity problem
Message posted on 25 Nov 2024 06:24 PM
Re: Mini box
Mini box says
you can't watch TV at the moment as there is a connectivity problem
Message posted on 25 Nov 2024 06:35 PM
Re: Mini box
No need to post twice @Tony167
Regarding your issue
Reboot the mini as above.
