Discussion topic: mini box connection
This message was authored by: Terry45
mini box connection
My mini boxes keep loosing there connection to the internet and the main box
Avatar for Terry45
Level 0 icon
Re: mini box connection
The screens freeze shortly after they connect, they then loose connection to the box and internet
@Terry45 Have you tried rebooting your main Q box ie
then
reboot the mini box
Avatar for Terry45
Level 0 icon
Done that a few times
@Terry45 who is your broadband provider if Sky what router do you have black or white ?
Hi @Terry45
Have you completely reset your minis.
Try a Network Reset on the minis. Start with the one nearest to the main Q box
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
Failing all of the above you may need a Sky Q WiFi Booster to position midway between your main Q box and the minis and you will need to contact Sky directly.
