Discussion topic: Mini box
This message was authored by: CL15
Mini box
We have two mini sky boxes neither are working
This message was authored by: daveNOS
Re: Mini box
@CL15 It would be useful if you could say what exactly is happening when you try to use them, that way we are not guessing and potentially giving out advice that won't help.
Re: Mini box
Hi @CL15
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
