Discussion topic: My sky box lost connection to WiFi and I can’t re connect
This message was authored by DarrenE2 This message was authored by: DarrenE2
Hi my bix has lost connection , and I can't reconnect
Re: My sky box lost connection to WiFi and I can’t re connect
Hi @DarrenE2
Assume this is your main Q box?
