Discussion topic: Mini box
Message posted on 01 Aug 2024 11:49 AM
Mini box
Hi,
One of the mini boxes is not working. I've switched on and off but it doesn't come on and the remote doesn't connect to the box
Message posted on 01 Aug 2024 11:55 AM
Re: Mini box
@ImranLodhi wrote:
Hi,
Hi @ImranLodhi
Reboot the mini as above.
If you had to press the Standby button on the front of the mini to switch it on then:-
With the mini on with green led try completly resetting your mini Bluetooth remote.
Press and hold 7 & 9 together on the mini remote until it’s led flashes four times.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
