Discussion topic: Mini box
This message was authored by: Polly17
Mini box
I have a mini box in the bedroom which I was told was independent of the main box however if the main box is in sleep mode the mini box does not come on automatically it can take up to one hour. The box is not working at all now I can't get connection even when main box is on
Re: Mini box
Hi @Polly17
If you want to use the mini inthe early hours then you need to make sure Q boxes are not in ECO standby.
See following link
https://www.sky.com/help/articles/using-the-standby-settings
Once you made sure that the boxes are in Active or None Standby try the following to reconnect the mini.
Reboot the mini as above.
Re: Mini box
Hi @Polly17   Try power rebooting the Main box first, followed by the Mini box. Check out the Standby settings on your boxes to prevent the Main box going into deep sleep.
There are various levels of independence, The Mini box can view, set recordings etc independently. However the Main box (Server) must be on or in Standby to service the Mini (thin client).
