Discussion topic: Mini box
Message posted on 03 Jun 2023 02:57 PM
Mini box
If I am watching the mini Q box in the bedroom if the main Sky Q box gets turned on the mini box stops working and the screen goes blue.
Message posted on 03 Jun 2023 03:05 PM
Re: Mini box
Hi @Gazz1984
Reboot the mini as above.
If the mini still does not work correctly try a Network Reset on the mini.
You will be asked to press the WPS button on the main Q box (not the mini).
