Discussion topic: Mini box
Message posted on 04 Jul 2025 06:31 AM
Mini box
Message posted on 04 Jul 2025 12:39 PM
Re: Mini box
Perhaps swap the one that's possibly faulty with one of the others and see how it reacts?
Message posted on 04 Jul 2025 12:52 PM
Re: Mini box
Already tried that still the same
Message posted on 04 Jul 2025 01:03 PM
Re: Mini box
Hi @bobsuthe
Have you tried a Factory reset on the problem mini in it's hidden menu.?
To enter hidden menu in the mini press Home and navigate down to Settings but do not select Settings.
Go to reset and select Factory reset
After the Reset you will have to re pair your mini Bluetooth remote If you use one.
If you cannot switch the mini box on with the remote after the Reset press the Standby button (Amber led) on the front of the mini box.
Make sure that you are pointing the remote at the mini box when you press 1 & 3 together.
Message posted on 05 Jul 2025 09:49 AM
Re: Mini box
Thx I will give it a go
