Discussion topic: Mini box will not scroll from main screen
Message posted on 25 Mar 2025 08:18 PM
Mini box main screen is frozen cannot scroll down or chose a Channel. When remote push the tv blinks and stays on the same screen .
caanot get out of this picture, have tried turning off and on, and reset button. May be broken as it is many years old.
Message posted on 25 Mar 2025 08:37 PM
Re: Mini box will not scroll from main screen
Remote probably needs re-pairing
Message posted on 25 Mar 2025 08:54 PM - last edited: 25 Mar 2025 08:55 PM
Hi @Terry1958
Reset your Q box remote by pressing and holding 7 & 9 together on the remote until it’s led flashes four times.
This will set it to infrared which will work all Q boxes. However the remote must be pointed directly at the Q box.
Switch your Q box back on and you then you should be able to get past frozen screen issues.
Once you get the Q box working make sure that you are pointing your remote at the Q box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
