Discussion topic: Mini box will is not connecting with main box
This message was authored by: Cookiethe+first
Mini box is not connecting to the main box
Re: Mini box will is not connecting with main box
@Cookiethe+first  Please try the steps in this guide https://www.sky.com/help/home/sky-tv/sky-tv-q/fixing-sky-q/fixing-connectivity/fixing-mini-connectiv...
Hi @Cookiethe+first
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
