Discussion topic: No satellite signal
Message posted on 26 May 2025 05:29 PM
No satellite signal
Message posted on 26 May 2025 05:32 PM
Re: No satellite signal
@Deeni Have you tried the steps in this link https://www.sky.com/help/home/sky-tv/sky-tv-q/fixing-sky-q/fixing-live-tv/no-satellite-signal/articl...
Message posted on 26 May 2025 05:37 PM
@Deeni
Check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
Message posted on 26 May 2025 05:52 PM
