Discussion topic: Mini box pauses and drops sound
This message was authored by: michael+167
Mini box pauses and freezes and sound drops or loses connection quite regular
Re: Mini box pauses and drops sound
@michael+167 Have you tried rebooting your main Q box ie
then
reboot your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for michael+167
Yes I have done that a few times this is a ongoing fault I have had minibox hardwired to router still the same fault
Hi @michael+167
Are you on Sky Broadband?
Yes 64mb fibre
@michael+167 wrote:
Yes 64mb fibre
Hi @michael+167
Try a Reset Settings in the main Q box hidden menu.
Yes I have tried that 1 before done forced software updates everything I have read on these forums and google
Hi @michael+167
No point in forcing updates if already on latest software.
Did you also try a reset Settings on the mini box after the reset settings on the main Q box?
is this a new issue with you mini or are you a new customer?
I have had a minibox for years with no problems but got 2 more about 2 months ago I have switched the 2 of them between 2 rooms but just get the same problem
Hi @michael+167
Is the problem mini in its  existing room or a new room when you added the minis?
I changed rooms the main box was in the room the mini is in now and I moved the main box into the room the mini was
What did yo do with th 2 satellite cables?
I ran a new twin cable Into the room with main box in now
hi @michael+167
Ok understood the swapping over (mini and Main Q).
Did this make the main Q box further away from the Sky Router? (Or is it on Ethernet?)
Yes its further away from router
