2
This discussion topic has been answered Discussion topic: Mini box not working
This message was authored by: JoJo81
Message says can't find activation server. Tried to go to settings, status, reactivate and confirm but just going round in circles.
Rebooted router too and made no difference.
Error code MR104
Re: Mini box not working
Error code MR104
Hi @JoJo81
Reboot the mini as above.
Error code MR104
Hi @JoJo81
Avatar for JoJo81
Thanks @oldfella after following the first step of rebooting main box, the mini box reconnected.
