Discussion topic: Faulty sky q
This message was authored by: Sav3
Faulty sky q
Sky q keeps cutting out
we have updated software and turned it off to reset it several times
This message was authored by: Padam_Padam
Re: Faulty sky q
When you say cutting out, what exactly do you mean? Is your screen going black? Are there any on-screen error messages? Have you tried replacing the HDMI cable between the box and the TV?
Re: Faulty sky q
Hi @Sav3
