Discussion topic: Mini box not working
This message was authored by: Nicmacjoe
My mini Q box has stopped working, we've tried to reset it a few times but nothing is working.
the main box is fine
Re: Mini box not working
Hi @Nicmacjoe
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
Avatar for Nicmacjoe
We have tried this but it's not working
Best you contact Sky for an Engineer then @Nicmacjoe
