Discussion topic: sky q minbox suddenly not connecting to main box - who can I call ?
Message posted on 23 Jun 2023 05:31 PM
My sky q mini box constantly keeps losing connection to the main sky q box. I've followed all steps restarting the boxes etc but I still keep getting the error message on the sky q mini that it's lost connection to the main sky q box
I've been through all the online help options - I really need to talk to a support person.
Message posted on 23 Jun 2023 05:44 PM
Re: sky q minbox suddenly not connecting to main box - who can I call ?
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
Message posted on 23 Jun 2023 05:47 PM
thanks - I've been through these steps several times .. My issue is the Q minibox connects and then quickly drops connection, in a minute or so... I have no issues with any other internet facing devices in my house or this room..
Message posted on 23 Jun 2023 05:50 PM
Other devices connecting to your internet is irrelevant @steve+hindmarsh unless you are on Sky Broadband.
Message posted on 23 Jun 2023 07:11 PM
Thanks - what's the best way of getting further support - none of the recommended steps resolve my issue
Message posted on 23 Jun 2023 07:13 PM
Contact Sky for an Engineer @steve+hindmarsh
