cancel
Showing results for
Search instead for
Did you mean:
Mini box not connecting
seanpmcm
Level 1
Fantastic Sky engineer came to house
first thing he did was check my Sky Q memory. I had no space. Too much recording. Delete loads of stuff that's not needed
Mini box connected once they did the reset
brilliant
hope it helps
1 REPLY 1
oldfella
Level 16
Re: Mini box not connecting
Message contains a hyperlink
brilliant
hope it helps
Hi @seanpmcm
You can send thanks to Sky in the following link.
https://helpforum.sky.com/t5/Send-Thanks-to-Sky/idb-p/sendthanks
