Discussion topic: Mini box lights up 5-10 seconds then goes off
This message was authored by: jamesk654
I have tried resetting which now keeps the red light on but cannot get it to work
Re: Mini box lights up 5-10 seconds then goes off
Hi @jamesk654
Have you tried pressing the Standby button (Amber led) on the front of the  minibox.
If this turns the mini box on
Try completly resetting your min9 Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
