Discussion topic: Mini box freezing
Message posted on 29 May 2025 08:21 PM
Mini box freezing
Mini box keeps freezing picture unable to watch live tv or recordings, works intermittently with apps. Have rebooted multiple times reconnected unplugged checked firmware and updated both mini and q box and still happening getting worse each day. Connected to main router connected through extender nothing helps. All other devices working normally and speeds are good.
need help as paying a fortune for something I can't use.
Message posted on 29 May 2025 08:24 PM
Re: Mini box freezing
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
