Discussion topic: Issues connecting sky q mini box
Message posted on 29 May 2025 07:13 PM
Received sky q mini, tried to connect had several issues, ended up getting replacement box but only stays connected for few minutes before it says cannot find sky q main box and internet not staying connected. Mini and router in same room and main box not that far away
how do I fix, I do not want to pay for a product that is not working
Message posted on 29 May 2025 07:16 PM - last edited: 29 May 2025 07:17 PM
Re: Issues connecting sky q mini box
Hi @Annandgerry
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
