Discussion topic: Mini box freezing / buffering
This message was authored by Jo126 This message was authored by: Jo126
Had SkyQ for several years.  New problem started few weeks ago.  When watching on mini box after about 30 mins (whether live, recording or app) starts freezing / buffering.  Have been pausing / rewinding to finish watching, when last did this on live TV went into continuous rewind.  Have reset to factory settings and swapped with another mini box but still getting same problem
Re: Mini box freezing / buffering
Hi @Jo126
Looks like a connectivity issue with the min location.
Reboot the mini as above.
Jo126
Thanks for suggestions but didn't solve problem.  Don't think a booster between Qbox and mini box will make any difference, has been same for several years without problem.
