Discussion topic: Satalite not working out
Message posted on 13 May 2024 08:42 AM
Hello, my sky engineer told me I need to replace my sky box with a stream service as my satalite dish will not work due to the forest outside, thanks.
Message posted on 13 May 2024 08:57 AM - last edited: 13 May 2024 08:59 AM
Re: Satalite not working out
hi @David260
SKY Q (& SKY +/HD) do need to have a Satellite dish that has clear sight of the Satellites.
If there is tree coverage or other obtructions which cannot be removed & no alternative position suitable then, probably, your only option to continue with SKY is streaming as advised by the engineer.
You will need to call SKY to discuss & arrange
BTW we are, primarily, just other customers here and help give advice
edit - to call::
If you have the MY SKY app I think you may be able to find a number there - especially if you are a SKY VIP member
If not go this page & scroll to the bottom and expand the link need more help & scroll down
https://www.sky.com/help/home
If you have SKY Mobile or SKY Talk land line then I think you can also call 150
