3
This discussion topic has been answered Discussion topic: Mini box drops the signal
This message was authored by: Sandy531
After setting up WiFi on the mini box it connects to the main Sky Q box for about 30 seconds then drops off
Re: Mini box drops the signal
Hi @Sandy531
Try resetting the connection to your main Q Box.
If you are on Sky Broadband and have the new Sky Max router then you need to connect your Q box as if you are on 3rd Party broadband.
Avatar for Sandy531
Any help would be appreciated
Hi @Sandy531
Avatar for Sandy531
Thank you Oldfella that sorted my problem 👍
