Discussion topic: Faulty sky box
Message posted on 04 Mar 2025 11:59 AM
Faulty sky box
A pop up box keeps appearing on the TV screen saying "The internet has been lost" because of this catch up, box set etc don't work, iv'e contacted my Broadband provider who have done various checks and they say it's possibly the Sky Q box at fault. Are you able to send a replacement ?
Message posted on 04 Mar 2025 01:25 PM
Re: Faulty sky box
Hi @Dexterleo27
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Regarding your issue.
