2
This discussion topic has been answered Discussion topic: Mini box and remote not working
This message was authored by: Millar83
Re: Mini box and remote not working
Hi @Millar83
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
With the mini box on with green led try completly resetting your mini  Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Hi @Millar83
Avatar for Millar83
I think it's working now thank you for help
