2
This discussion topic has been answered Discussion topic: Sky q saying no network but checked and followed all instructions and still saying no network
This message was authored by: Mrsclarkie
About a week ago, having worked perfectly our sky q tv gave a message saying not connected to Internet.  Have followed all the sky self help instructions and same for our sky router and no change.  The sky q checker isn't working.  We can watch tele but none of the catch up tele etc.  anyone got an idea what else we can try?  Haven't done Ethernet cable but not needed to before.  Is it a call to sky or engineer visit required ?  Very frustrating  as nothing changed as far as I'm aware.  Thanks in advance if anyone can help
Re: Sky q saying no network but checked and followed all instructions and still saying no network
Hi @Mrsclarkie
On Sky broadband hold the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
On Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
Hi @Mrsclarkie
Avatar for Mrsclarkie
Thank you, that worked.  I was pressing the reset button thinking it was the Wps button ... d'oh!
