Discussion topic: No sat
Message posted on 28 Jul 2024 05:53 PM
No sat
Our screen says satellite signal - unlocked, and LNB type is SCR. Both signal strength and quality are 0. Can you please advise next steps?
Message posted on 28 Jul 2024 06:06 PM - last edited: 28 Jul 2024 06:06 PM
Re: No sat
@LewisCoultas if you are not on a communual dish and you have your own dish, you will need to enter the engineers menu
and change the LNB type to wideband
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
select setup > LNB type > wideband select then exit out of the menu then reboot your Q box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 28 Jul 2024 07:06 PM
Re: No sat
Already tried that but doesn't seems to make any difference. Any other idea on what's wrong?
