Discussion topic: Mini Q to main box connection
This message was authored by: missfinsta
Every morning we are having to reactivate connection to the main box. Normally end up having to go turn the main box on for it to eventually work. It didn't start this way. And surely the whole point of the mini Q is that we have the TV working in  another room?
Re: Mini Q to main box connection
Hi @missfinsta Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, do the same with the Mini box?
Hi @missfinsta
Try resetting the mini connection by carrying out a Network Reset on the mini.
This message was authored by: Invisiblename
You say "turn the main box on"; just checking that you mean take it out of standby, and not that you are completely powering off your main box?
I am just another Sky customer!
