Discussion topic: Mini Q box Losing internet connection
This message was authored by: Posy43
I have had a sky Q mini box for a few years now with absolutely no problems at all. Occasionally I have had to reconnect to the network but on Thursday evening it suddenly went off I tried to reset but nothing happened. Since Thursday I have reset my router several times, the main box several times reset my network several times. If I go through the whole network reset including re entering my wifi password it does connect again and looks fine except the connection is lost again in less than 2 minutes . The box is not connected to the network and can no longer find the skyQ main box . I am on BT using their router and booster disc which is ibviously working fine as my computer Alexa and any other wifi gadgets are all still working fine.
there is also no problem with the main sky Q box can anyone help?
Re: Mini Q box Losing internet connection
Hi @Posy43
Reboot the mini as above.
Highlight Status and then select Reset on the right hand side. Follow instructions to WPS with main Q box. (You cannot connect minis to non Sky Network WiFi)
Avatar for Posy43
Thank you for your reply but I have done all of that several times over.
why would I suddenly need a Sky Q WiFi Booster when it has been working fine for years?
Hi @Posy43
In your original post you mentioned inputting password.
Assume this was not on your mini box.
This message was authored by: Mindy22
I've been having similar issues and reset wifi router (SKY) and mini boxes and main sky Q box many times. It really is starting to frustrate me and is either (in my opinion) a hardware issue for those of use with original first edition sky Q and sky mini boxes and/or router or a firmware/software glitch that these older boxes can't handle.
please, please, please don't suggest that I turn the box off / reset. Anyone with common sense has googled this issue and done this many times already !!!
Avatar for Posy43
Hi @oldfella
I have figured it out now, or rather my husband has I wasn't aware we already had a sky booster. When the engineer installed our sky Q he put the booster box on top of one of the kitchen cabinets
when we checked that it had lost connection. Once we reconnected that the mini box connected automatically.
thank you so much for all your help
It's not just the v1 boxes
So a massive issue I guess a cross the stock of Q boxes around the country.
many creaking at the seams.
my boxes fan comes on a lot and getting to a stage of needing a box swap out but if that doesn't work medium term then it will mean a rethink on whether to stick with sky after 20 years.
OK. No one on here is going to try to persuade you to stay in the club 😁
HDR is worth having though so should upgrade anyway but particularly if the box is getting noisy.
