Discussion topic: Mini Box Losing Connection
This message was authored by V1CK180 This message was authored by: V1CK180
My Sky Mini Box keeps losing connection, we had the dish moved because of the trees to the front & the Sky Q box is now ok but my mini box keeps losing connection to the sky Q box
Re: Mini Box Losing Connection
Hi @V1CK180
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.
V1CK180
I've been trying to find how to get a wifi booster but cant see it anywhere on the website. Can you tell me how to contact as phone cuts out or only automated voice it seems impossible to contact sky now
Hi @V1CK180
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
This message was authored by Andysutton This message was authored by: Andysutton
Just solved mine by plugging in a wifi booster into the sky box and mini box using  Ethernet cable.
