Discussion topic: Mii box not connecting.
Message posted on 24 Oct 2023 05:38 PM
Hi,
My Sky mini box will not connect to my SkyQ box. Internet connection is to the SkyQ WiFi and not my household WiFi.
Message posted on 24 Oct 2023 05:57 PM - last edited: 24 Oct 2023 06:00 PM
Re: Mii box not connecting.
@Dhiren wrote:
Hi,
Hi @Dhiren
Yes that is correct.
If you are 3rd party Broadband minis will only connect by WiFi to the main Q box.
Reboot the mini as above.
