4
This discussion topic has been answered Discussion topic: Microphone, for asking for a programme not connected.
This message was authored by: kath1234
 New LG TV. I wanted the remote to voice activate finding a programme, but no luck.
Thank you
Kath
Re: Microphone, for asking for a programme not connected.
Thank you
Hi @kath1234
Sky Q Voice remotes are only for searching Content on your Q box and not your Television set.
Your remote will only control Television volume, Mute and Input select and need correctly pairing.
Thank you
Hi @kath1234
Avatar for kath1234
Level 4 icon
Thank you for your quick reply. All working.
Kath
Avatar for kath1234
Level 4 icon
Help,
can't alter the sound at all now on my sky remote .
Thank you
Kath
Hold down 1&3 to start the TV pairing process.
