This discussion topic has been answered Discussion topic: Microphone, for asking for a programme not connected.
Message posted on 02 Oct 2025 01:22 PM
New LG TV. I wanted the remote to voice activate finding a programme, but no luck.
Thank you
Message posted on 02 Oct 2025 01:29 PM
Thank you
Hi @kath1234
Sky Q Voice remotes are only for searching Content on your Q box and not your Television set.
Your remote will only control Television volume, Mute and Input select and need correctly pairing.
Thank you
Hi @kath1234
Message posted on 02 Oct 2025 01:56 PM
Re: Microphone, for asking for a programme not connected.
Thank you for your quick reply. All working.
Message posted on 02 Oct 2025 05:01 PM
Help,
can't alter the sound at all now on my sky remote .
Thank you
Message posted on 02 Oct 2025 06:41 PM
Hold down 1&3 to start the TV pairing process.
