Discussion topic: Message onscreen saying satellite fault
This message was authored by: Jedhart1690
Picture distorted goes blank saying problem with satellite signal
Re: Message onscreen saying satellite fault
https://www.sky.com/help/articles/sky-tv-no-satellite-signal
@Jedhart1690
Firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. The link above may give you the opportunity to arrange an engineer to check the alignment of your dish.
If you are connected to a communal dish you’ll need to liaise with you building management company / landlord who will have their approved engineers to contact.
Note: A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
