8
This discussion topic has been answered Discussion topic: Message on screen re: BBC HD
This message was authored by: Craftypolly
can someone explain why u get this message when I record a programme on BBC it doesn't appear when I watch it live.  My sky Q box is an HD box so I don't need to do anything but this banner is very annoying because it blocks out 1/3 of the screen and is unwatchable.
Avatar for Craftypolly
This message was authored by: Craftypolly Answer
Re: Message on screen re: BBC HD
I have sussed the problem. Setting up to record a bbc program from my sky go app is in SD which why I get the message.  Setting up a recording from tv is ok.
hi @Craftypolly
I think it is likely that you have downloaded an SD version of the programme - either that or you have recorded it from the SD version of the channel.
If downloading then you probably need to make sure you download an HD version
Maybe check to see if the Recording is set to be from the SD version of a BBC channel?
Glad you have sussed it.
Thanks for letting us know - there is a chance others will have a similar problem and this was not something I had thought of, so useful to know
This message was authored by: Petroma1613
Why am I continuing today to receive on screen messages telling me that BBC broadcasts will stop on 8th Jan. I am a Sky+HD customer and today is the 9th Jan
The BBC SD channels closed yesterday as planned. If you're seeing the message today you're watching a recording from the SD channel.
No, I was watching Breakfast on BBC1
This message was authored by: cuke
So was I on channel 101 and there was no message..
