Discussion topic: Message on screen - No Hardisc there is a problem with your disk drive
Message posted on 04 Aug 2024 05:17 PM
Sky box come up with is message when trying to turn on No Hardrive
There is a problem with your hard disc drive
Message posted on 04 Aug 2024 05:19 PM
Re: Message on screen - No Hardisc there is a problem with your disk drive
Hi @Spanner-68
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
