Discussion topic: Using voice crashes Sky Q box
This message was authored by Resident1 This message was authored by: Resident1
Has anyone else had their Sky Q box crash when attempting to use the voice commands?
It's only started happening recently so I suspect an update gone awry.
Any attempt to use the voice function on the remote crashes the entire box
I press the blue button and the box responds with the listening graphics on screen, it shows what I've said then immediately crashes, leaving the voice command graphics on screen.
The remote then does nothing, the phyical buttons on the box don't respond & the only way to "fix" it is to pull the power cable and restart the box.
All functions work perfectly except for the voice commands
Re: Using voice crashes Sky Q box
Hi @Resident1
certainly not due to any Software update
Resident1
Thanks for the info however this has already been done and still the problem persists
Hi @Resident1
Have you tried rebooting your Broadband router?
