Discussion topic: TV not working after removing mini box
This message was authored by: Kingsknowe12
Removed mini box from conservatory and returned to Sky.  My TV is not working now. Any help please
Re: TV not working after removing mini box
Hi @Kingsknowe12
Does your Television have a terrestrial aerial?
If it does have you changed the Television input to TV tuner:
Avatar for Kingsknowe12
Level 0 icon
Not sure. Need to get my husband to check My main TV is still with Sky
Hi @Kingsknowe12
If you have removed the Sky mini from your conservatory TV and no Q box is connected to it then it needs a terrestrial aerial to get Freeview channels.   If it is connected to the internet and is a Smart TVnthen it will function with inbuilt Apps.
Or are you saying that your Main TV with the main Q box is not working now?
Level 0 icon
My main tv is working fine.  Will check out aerial thanks
