7
This discussion topic has been answered Discussion topic: Mark h
This message was authored by: Mh41
Mark h
Anyone know why sky Q mini won't connect to internet?
This message was authored by: Chodley Answer
Re: Mark h
To the Q?
it's possible hard wiring it to the router might work as long as it can still "see" the Q through that. If the Q is hardwired it'll be fine. If it's on wifi... maybe.
Re: Mark h
@Mh41 who is your broadband provider and how are you trying to connect it
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Re: Mark h
@Mh41
Because they don't: connection is to the main Q box.
Avatar for Mh41
Re: Mark h
Sky broadband , Wi-Fi connection, , sky are sending new mini box, we will see if that fixes it, thanks for replying all 😀
Re: Mark h
Hi @Mh41
If you are on Sky Broadband with the the new Max fibre router then yo still need to connect to the main Q box using WPS.
Avatar for Mh41
Re: Mark h
I'm going to hard wire this new mini box thus avoiding any future issues, disabling Wi-Fi
Re: Mark h
To the Q?
Avatar for Mh41
Re: Mark h
New Qsky mini arrived next day, impressive, hard wired it  into sky router, main box also wired, disabled Wifi on mini box. All ok for 3 mins, then error message, 'cannot connect to sky box's, reboot both boxes, same thing happened , another reboot of mini and viewing  lasted all evening, why was there still a connectivity issue? When will it loose connection again, so unstable, esp . Puzzlingly both boxes are wired?
