Discussion topic: Main sky q won’t work but all mini q do. Main q behind frame tv.
This message was authored by: Salcombe+Frame
Main Q box behind samsung frame TV. Keep getting 'check device power' screen. All minis working fine. Switched off at main plug many times but still get same message on start up.
please can anyone help?
thanks
Re: Main sky q won’t work but all mini q do. Main q behind frame tv.
thanks
Could be a TV message and not from your Sky Box @Salcombe+Frame
Try rebooting your TV Set.
thanks
Hi @Salcombe+Frame If the Mini boxes are working  then the main SKYQ box is also, the message you have is from your TV and may relate to the HDMI connection from the Main SKYQ box and to the  TV?
