Discussion topic: No signal
Message posted on 25 Jul 2023 09:28 AM
No signal
no signal in Billingshurst for over a week now network says it's fine but definitely not.
Message posted on 25 Jul 2023 09:37 AM
Re: No signal
@Richard+42 If it's a no signal that is a message from your TV, are you sure it's not a no satellite signal;? If so follow these steps to the end
A No satellite signal suggest an issue with either the box or dish, it won't be a wider issue as the forum would simply be flooded with literally 1000s of posts of the same type.
Message posted on 25 Jul 2023 10:41 AM
Re: No signal
@Richard+42 wrote:no signal in Billingshurst for over a week now network says it's fine but definitely not.
What "network" are you referring to? Sky's live transmissions are sent via a satellite, so if you mean the internet, that is irrelevant. As above, 'No signal' means that the TV is not receiving the required input from the Sky box, so make sure you have the correct input selected on your TV.
